14 years agoDDR2 on two sides - one controller
Hello, We are using an Arria II with DDR2 chips on two sides of the FPGA. Is there a way to aggregate the two and control them with one instance of the DDR2 HP controller? We are using HP and...
14 years agoWith this approach, the commands to the DDR have to complete at the same time for both chips. I don't know if the DDR command completion time is cycle-based or depends on other parameters / conditions.
Do you know if I can guarantee that the same command sent to the both chips at the same time will complete at the same clock cycle?
