14 years agoDDR2 on two sides - one controller
Hello, We are using an Arria II with DDR2 chips on two sides of the FPGA. Is there a way to aggregate the two and control them with one instance of the DDR2 HP controller? We are using HP and...
14 years agojosyb,
My problem is that I do not know how to setup the HP controller wizard to generate independent signals for two chips. It looks like I can generate independent signals for clocks and some other signals, but not for the address signals. I know how configure the wizard for two chips that share the same address lines. When reading page 1-4, it seems to say that the controller can handle chips that are located on opposite sides of the device, but it does not indicate whether the chips can be completely independent (signal-wise) of each other. You still think it should be possible?
