19 years agoDDR2 on Stratix II GX PCI-E Dev kit malfuncitoning
hi, I have Stratix II GX PCI-E Dev kit. I have already successfully ported NIOSII, On-chip RAM, JTAG UART, PIO LED, PLL, MY own LED on it and it works. I had so much trouble with DDR2. I ch...
18 years agoHello,
I think you are profession in my issues, I need your help. I have some troubles with my design with Stratix II Devices. I use MegaWizard, Quartus's Web edition, to create ALTMEMPHY. It releases many files such as: *_alt_mem_phy_reconfig_sii *_alt_mem_phy_ sii alt_mem_phy_defines alt_mem_phy_sequencer.vhd *_altmem_phy_sequencer_wrapper.vo ... Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module? To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice. I'm very impressed by ALTMEMPHY but I can't use it for a long time. Thank you in advance!
