19 years agoDDR2 on Stratix II GX PCI-E Dev kit malfuncitoning
hi, I have Stratix II GX PCI-E Dev kit. I have already successfully ported NIOSII, On-chip RAM, JTAG UART, PIO LED, PLL, MY own LED on it and it works. I had so much trouble with DDR2. I ch...
18 years agoI am sorry to trouble you. I want to ask you a question.
Does it use external parallel resistors on DQ and DQS pins between stratixII Gx and DDR2 chips on Stratix II GX PCI-E Dev board. Now I am designing a stratix III pcb board with two DDR2 chips. The space of the pcb board is limited. It can't place so many termination resistors. I wonder whether the external parallel resistors is necessary. I don't have the schematics of Stratix II GX PCI-E Dev board. I look forward to your answer. Thanks. My Email [email protected]
