11 years agoDDR2 IP Controller Write Performance Question
Simple performance question: What is the performance improvement (in general terms) of doing 4W burst writes vs. 4 single writes to consecutive addresses? Since 4 data words need to be written in e...
11 years ago --- Quote Start --- Are you talking about the Altera DDR2 controller? I don't think your assumption is valid that the controller will queue up 4 single-word writes on the host side, recognize that the word addresses are consecutive, then generate one 4-word burst to the memory. I think it will generate a separate burst write to memory in response to each single-word write. So one 4-word burst on the host side will be way more efficient than 4 single-word writes. At least 4x faster I would think. You should try both approaches and see what you get. --- Quote End --- Yes, it's the Altera DDR2 full-rate controller running at 133MHz. I assume burst writes are there for a reason, so I guess I'm asking if someone can explain where the improvement comes from and how much. Assuming the controller won't create an SDRAM burst write command from multiple single requests, I can see where one SDRAM command with 4 data words (2 clocks for data transfer) would be faster. Does anyone know what the Altera DDR2 controller will or will not do for writes in terms if efficiency?
