14 years ago
DDR2 HPC2 Timing Simulation fails
i am trying to get the example design for the DDR2 Memory controller (HPC2 with ALTMEMPHY) to work. I have spent already a whole week on this issue, but I cant get it to run. I am using Quartus II 11.0 (tried with 9.1 too) and modelsim se 6.6d. I am trying to implement the design on a Stratix III EP3SL340H1152C2. The behavioural simulation works fine, but when I generate the timing model the simulation fails with timing violations (HOLD HIGH and LOW on stratixiii_ddr_io_reg), even though quartus met all timing constraints. I tried the generic memory model and the micron vendor specific memory model (because it was used in the tutorial). I assigned all pins according to the board i am using (Altera DE3 Board).
I followed the advices in the tutorials and manuals. I executed the tcl script and included the *.sdc files in the project. I adjusted the parameters of the controller as specified in the manuals. It still doesn't want to work and I have no idea how to fix the problem. Please help me with this issue. I am really desperate and frustrated atm. I attached the quartus logfile and an image of the modelsim waveform. If u need anything else, please let me know. Thank you very much in advance.
Martin
P.S. The project i generated the logfiles with, does not contain the exact pin locations. Can't use the actual project, since it is confidential. I assume the simulation should work anyway.
    I made a funny observation this morning. I turned on the FPGA, uploaded the design and it worked well for a few minutes. No errors whatsoever. Then after a few minutes the error count goes up. Until it reaches the same error rate as before. So I assume that it has something to do with the temperature of the FPGA. But as I am concerned this shouldn't happen. Especially since the temperature is only about 43 °C (109 °F). Unfortunately I am not a electrical engineer, so I can hardly explain why this happens.
    Martin
