15 years agoDDR2 HPC2 Timing Simulation fails
Hello, i am trying to get the example design for the DDR2 Memory controller (HPC2 with ALTMEMPHY) to work. I have spent already a whole week on this issue, but I cant get it to run. I am using ...
15 years agoHi,
I put up a fresh quartus project with my custom IP cores and complete pin assignments. I added the ctl_cal_success, ctl_cal_fail and ctl_cal_warning to signaltap. Unfortunately the signal ctl_cal_fail is asserted. Quartus met the timing requirements only without signaltap. When I insert SignalTap into the design the timing fails quite miserably. I got a -4ns setup slack for: seq_oct_oct_delay[0] => acq_trigger_in_reg This could be the reason why the calibration fails. Would it help, if I use another clock for SignalTap? Right now I use the 100 MHz clock of my PLL. Another problem might be the following warning: --- Quote Start --- Critical Warning: No exact pin location assignment(s) for 2 RUP, RDN, or RZQ pins of 2 total RUP, RDN or RZQ pins Info: RUP, RDN, or RZQ pin termination_blk0~_rup_pad not assigned to an exact location on the device Info: RUP, RDN, or RZQ pin termination_blk0~_rdn_pad not assigned to an exact location on the device --- Quote End --- Do I need to connect these PINs to the design? There are no ports that I could connect them to. Another warning I am worried about: --- Quote Start --- Critical Warning: Memory clock pin mem_clk[0], mem_clk[1] must be placed on the same edge of the device Critical Warning: mem_clk[0] was placed on the right edge of the device Critical Warning: mem_clk[1] was placed on the bottom edge of the device --- Quote End --- How can I place the mem_clk on the same edge? The PIN assignments are fixed according to the DE3 manual. Thank you very much in advance. Best regards, Martin
