15 years agoDdr2 hp
my sopc system includes A nios , a pio, an onchip memory ,and a ddr2 hp . I want to use the ddr2 chip as my NIOSII program's running space.so,in IDE,i set the program memory (.text ) to the ddr...
15 years agoIt seems there is a communication problem to your ram.
Have you analyzed the timing in your system? Are you using Classic or Timequest timing analyzer? You can add Onchip-RAM to your system, and run the memtest-template from it to check your RAM hardware.
