15 years agoDDR2 HP simulation fail in StratixIV
hi all, I want to simulate DDR2 HP ip core. I use the altera example as top file. According to altera docment, I do the following: 1. I download simulation model from Micron and add `define...
13 years agoHallo Tom,
I would like to ask you if you could solve this problem? If yes, How did you do it? I am having a similar situation when I use the DDR2 HPC II with my own testbench. Apparently, it is because the Modelsim-ALTERA edition that I am using does not support the mixed HDL. However, when I am simulating the DDR2 HPC II with the example generated by the megawizard I do not have any problems. Therefore I am very curious what could it be this kind of error. I suppose it is a problem loading the libraries. :S Thanks, Juan
