15 years agoddr2 high pref controller
hi i got qoartus 10.1 and when i try to add the ddr2 high performance controller(with altmemphy) it bring me an eror about java script --- Quote Start --- Error: An unexpected error...
15 years agoHi talzohar
I get the very same error msg, when trying to edit an old and well working design with a DDR controller. It makes no difference wether I try to use DDR, DDR2 or DDR3 controllers, or wether I use Q10.1 or Q8.1 ( that I keep for safety ). Surfing google I found a lot of similar error msg's relating to other Java applications, usually pointing to a problem in the reg-db. It looks like it is a path somewhere that is not set correctly.
