17 years agoDDR2 High Performance Bidirectional I/O Error
Hi I am using Altera Stratix-III FPGA development board with EP3SL150F1152C2 FPGA. I instantiated DDR high performance IP core in SOPC. Before compilation, I also executed the scripts generated...
17 years ago --- Quote Start --- Could setting "differential pair" in pin planner for all "ddr2_dimm_clk" solve such errors ? My understanding is that ddr2_dimm_clk and ddr2_dimm_clk_n should use differential I/O standard, and each ddr2_dimm_clk and ddr2_dimm_clk_n should paired to each other in Pin Planner "differential pair" column. --- Quote End --- You would think so, but apparently there is a double constraint. The settings for differential I/O have be set at both the pin side and the DDR2 Controller side.
