17 years agoDDR2 High Performance Bidirectional I/O Error
Hi I am using Altera Stratix-III FPGA development board with EP3SL150F1152C2 FPGA. I instantiated DDR high performance IP core in SOPC. Before compilation, I also executed the scripts generated...
17 years agoI received similar kinds of errors trying to run the DDR2 High Performance Controller on a Terasic DE3 Stratix III Board.
The doing the following would bring up pseudo-differential errors -not setting the use differential dqs or enable dynamic parallel on-chip termination (oct) options for the ddr controller under PHY Settings -not running the following 3 scripts: <ddr_ctrl_name>_phy_dq_groups.tcl <ddr_ctrl_name>_phy_ddr_pins.tcl <ddr_ctrl_name>_assignments.tcl I hope this helps
