16 years agoDDR2 fitter error in quartus 9.1
i am getting the below error when i try to run fitter, my design uses DDR2 controller
Error: Too Few items in collection (0) for list write_clock_id while executing "error "Too Few items in collection ($i) for list $vlist"" (procedure "sett_collection" line 14) invoked from within "sett_collection write_clock_id [get_pins -compatibility_mode $write_clock_pattern]" (procedure "add_requirements_for_instance" line 378) invoked from within "add_requirements_for_instance $corename $inst t board ISI $ddr2_sdram_data_phy_use_flexible_timing" ("foreach" body line 3) invoked from within "foreach inst $instance_list { post_sdc_message info "Adding SDC requirements for $corename instance $inst" add_requirements_for_instance $corename $..." (file "ddr2_sdram_data_phy_ddr_timing.sdc" line 653)3 Replies
I'm getting the same error... do you have the answer?
Thanks - Altera_Forum
no i am not able to remove the error in quartus 9.1, insted i used subscribtion edition(30 day free) to compile my ddr2 deisgn in arria ii.
bhupesh - Altera_Forum
I remember seeing a similar error. Try copying the following TCL files into the build directory(Where the QPF file is located).
<Project name>_phy_autodetectedpins.tcl <Project name>_Controller_phy_ddr_pins.tcl <Project name>_Controller_phy_ddr_timing.tcl <Project name>_Controller_phy_report_timing_core.tcl I think this will get rid of the errors. Kumaran
