16 years agoDDR2 Controller Write Error
I'm getting an odd write error with a DDR2 high-performance controller. After performing a large number of reads/writes in a memory test program, the controller gets into a mode where one byte lane's...
15 years agoDid you ever find a solution to your DDR2 intermittent write error? I'm having a similar problem, except that I have one byte of four that will get behind about .00001% of transfers.
Timing analysis says everything should run fine (@125 MHz) Thanks
