16 years agoDDR2 controller: error msg for bi-directional clock.
Hi, I'm getting the following error when trying to fit a full-rate DDR2 controller to my Stratix III device. "Error: Bidirectional pins mem_clk[0] and mem_clk_n[0] with pseudo-differentia...
16 years agoHi,
I'm still getting the same error message. I find that the ddr2 controller works as a half-rate but not as a full-rate. What would be different about the two with respect to pin assignments? Are there any assignments that I should add to the assignment editor which are not needed for a half-rate? Is there a tutorial for a full-rate controller? I was only able to find them for half-rate ones. I'm using the Terasic DE3 board, is there an issue with using full-rate controllers on this board? Thanks.
