16 years agoDDR SDRA IP local address
I try to use DDR SDRAM IP controller. I need it for 1 Gbyte DDR memory. after setting the block and the controller sign that we have 1 Gbyet memory we only get 26 address line, and we need 27 ad...
16 years agoThank you again.
On the first time we did try to use all the 26 address line and we saw that we trying to write and read from address 0 & 1 and we find out that the data was same, after that we r that in the ddr controller paper was the next lines: ■ Full rate controllers The width of this bus is sized using the following equation: For one chip select: width = bank bits + row bits + column bits – 1 For multiple chip selects: width = chip bits + bank bits + row bits + column bits – 1 If the bank address is 2 bits wide, row is 13 bits wide and column is 10 bits wide, then the local address is 24 bits wide. To map local_address to bank, row and column address: local_address[23:22] = bank address [1:0] local_address[21:9] = row address [13:0] local_address [8:0] = col_address[9:1] The least significant bit (LSB) of the column address (multiples of four) on the memory side is ignored, because the local data width is twice that of the memory data bus width.
