18 years agoDDR or DDR2 SDRAM controller
I builded a DDR or DDR2 SDRAM controller using QuartusII MegaWizard Plug-In, ip toolbench. It should have self-testing function. But I can not run it in QuartusII's simulation. No DDR address, data...
17 years agohow to get the gate level file "*.vo"
my modelsim display: ** Error: (vsim-3033) E:/FPGA/video_delay/ddr2_auk_ddr_sdram.v(249): Instantiation of 'auk_ddr_controller' failed. The design unit was not found. then I add the auk_ddr_controller.vhd(the file in the ip folder) to the work. modelsim display : ** Error: F:/altera/72/ip/ddr_ddr2_sdram/lib/auk_ddr_controller.vhd(1): expecting: ARCHITECTURE CONFIGURATION ENTITY LIBRARY PACKAGE USE thank you very much
