17 years agoDDR local_wdata to mem_dq incorrect outpu
Hello, I need help about the proper write timing of DDR Controller, because the written data in local_bus is not properly outputed in the mem_dq. I'm not sure if the timing is correct becaus...
17 years agoGlad you got the problem fixed. I have no clue why altera likes to believe that these cores follow the avalone spec. It says very clearly in section 3.10.2.1 and figure 3.12 of the avalone spec(mnl_avalon_spec.pdf) that you can pause a burst write transfer by deasserting the write command. Evidently altera likes to ignore this fact and not talk about it. Oh well.
