18 years ago
DDR and DDR2 Conroller: local_size
Dear,
I am studying the DDR&DDR2 Controller IP. Could you please explain me the following issue:
- In parameter setting phase, I set Burst Length = 4. So, when controlling the IP, I can use local_size = 1 or 2.
- In case of local_size = 1.
+ DDR supports Burst Terminate(BT) command; so after two write/read cycles, command BT is issued to the memory
+ DDR2 does not BT command. How does the IP stop the burst write/read? Can we use loca_size = 1 in this case?
Thanks!
1 Reply
    Your questions seem to me related to a full rate design with 1:2 multiplexing. I would expect, that the controller core is performing dummy read respectively partial write cycles to fill the burst length. DM must be connected to allow this, however.
