10 years agoDCFIFO: shoud i set flase path timing
HI, Im using a DCFIFO (dual clock fifo) to transfer clock domains. i genreated a DCFIFO, but i get timing violations from 1 clock to the other regards Fifo components. should i "set_f...
10 years agobe aware if you use the usedw that they get updated with a latency of one clock-cycle...
