10 years agoDCFIFO: shoud i set flase path timing
HI, Im using a DCFIFO (dual clock fifo) to transfer clock domains. i genreated a DCFIFO, but i get timing violations from 1 clock to the other regards Fifo components. should i "set_f...
10 years agoyes, but you have to take care about the fill level. Do not write to a full Fifo and not read from an empty Fifo. I'm using wrusedw and rdusedw for checking that.
Jens
