10 years agoDCFIFO: shoud i set flase path timing
HI, Im using a DCFIFO (dual clock fifo) to transfer clock domains. i genreated a DCFIFO, but i get timing violations from 1 clock to the other regards Fifo components. should i "set_f...
10 years agoHi,
I'm also using dc_fifo for synchronizing data between different clock domains. So I set that clocks exclusive in timequest: set_clock_groups -asynchronous -group {clk_a} -group {clk_b} No timing violations occur. Jens
