16 years agoDCFIFO rdusedw and rdreq
Dear All, I've instantiated a DCFIFO (Cyclone II). The read and write clocks are not synchronized to each other. I'm using a signal synchronized to the rdclk as the rdreq which is approxim...
16 years agoThe rdreq signal is high only for one clock duration (of the rdclk) and low for the remaining four clocks.
I understand that the rdusedw is updated with the rdclk. I also understand that the rdreq is just used as a read enable and there is no significance of it's edge. But what I expect is that the rdusedw should get updated when something is 'read' from the read port, not at other clock cycles of rdclk. Nagaraj
