14 years agoDCFIFO Megafunction simulation problem
Hi, I am attempting to use DCFIFO megafunction in my design, but i can't get it running!! The input data to be written to FIFO is (45 bit parallel) streaming video data clocked at 5MHz (...
8 years agoHi, did you solve the problem?
following is my problem: when I generated a DCFIFO with read clock different from writing clock, the rdempty signal always keep high, and rdusew signals don't function, too. so I can't read data from FIFO. after checking the wrempty and wrusew signals, they function correctly, so I use wrusew to detect and correctly got the desired. following is my verilog: https://www.alteraforum.com/forum/attachment.php?attachmentid=14816 https://www.alteraforum.com/forum/attachment.php?attachmentid=14817 https://www.alteraforum.com/forum/attachment.php?attachmentid=14818 so my qustions are: 1. what is wrong with rd signals? 2. when using the same clock for both rd and wr clock, everything works fine(using either wrempty or wrusew to detect), but when rdclock is different from wrclock, either faster or slower, the data readout is not exactly what it received.
