11 years agoDC in the CIC-FIR filter result
Hi All, I have attached a figure showing my filter issue. Please subtract 28 MHz from the x axis values (it was a typo). It is apparent that there is a strong DC peak in the plot. My question i...
11 years agoHi Kaz,
My DC issue was mainly happening in the mixing. I have attached the matlab plot of my baseband results. The input is 28.05 MHz which is 124 dBm above 28MHz where as the nco 28 MHz cosine/sin is 115 dBm above 28.05MHz. These show that the input and nco sin/cos does not cause major DC. However, in the 16 bit baseband result (i+j*Q), the DC is 1 dBM and the 50KHz peak is 82 dBm. This is a strong DC. Interestingly, in the 32 bit baseband plot, the DC has been reduced to -71dBm. This shows that increase in the baseband bit width reduces the DC significantly. Do you have any idea why? Many Thanks, Lee
