15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoWell, as You can see, I don't use Nios to form IP packets anymore. All the layers MAC+IP+protocol are generated in hardware.
