15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoSocretes your posts have been very helpful to me. I plan on testing out some more of your work later tonight, however did you ever figure out a way to increase the size of the payload? I would suspect part of the speed problem results from not making the ethernet packet as large as possible.
