15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoOk I am moving forward. It is very easy to send udp data using udp_send() in InterNiche, it does everything You need, but I want to prepare UDP data in hardware, so I want to use ip_write only.
That is also pretty easy, but I face some problems: I prepare the packet same as I would use in udp_send(), but it forms a packet without src/dest ip adresses and I don't know how to set them? The other parts (except adresses and payload) of the packets are OK. Another problem that the payload is always 10 bytes, no matter if I set the payload length 26 and add required octets to the packet. Maybe someone also had such problems? here (http://pastebin.com/d1a4qtjg) is the source code. EDIT: SOLVED -> Need to add src and dest ip addresses through ip struct:
own_address = ip_mymach(pkt->fhost);
pip = (struct ip *)(pkt->nb_prot - sizeof(struct ip));
pip->ip_src = own_address;
pip->ip_dest = pkt->fhost;
---------------------------------------- Now moving towards to add DMA to move payload from hardware to pkt buffer.
