15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoYes 1) is the best solution. If you can't pause the stream you generate when you want it, then yes you'll probably need a fifo before the mux.
