15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoWell I've successfully done the IP and UDP header forming, checksums are ok. Did You use multiplexer before TSE? Maybe You are also working with video streams?
