15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoHello again,
I've made the IP header and UDP checksum in hardware, so now I can forward 32 bit data to Nios. Since I need full ethernet support (ICMP and ARP), I need to know how to put that streaming data to InterNiche buffer? Are there any documentation? I can also use LwIP, but it seems like it is not well documented how to use it in Nios...
