15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoIf the only packets that you need to send are those generated by hardware, then you don't need the DMA and can directly connect your IP to the TSE core.
If you also need to send packets from the CPU, then you'll also need a DMA and a multiplexer to connect both the DMA and your IP to the TSE core, like they do in the offload example.
