15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoWell, I did not try to solve those errors (5 critical warnings)
Since my packet length is always the same, I am thinking of forming ip and udp headers in hardware and use packet send directly through TSE, like this is done in offload example. I am not sure if I need DMA, seems like it may be not useful now?
