15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoThe old design made with Q9.0 fails timing @ 10.1sp1, so the design doesn't run - Nios is not found in the system (yes, sysid component is in the system). I've checked the source, however such simple project it should be, but use RTOS - which makes it complicate...
