15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoWhat about packet receive then? In this phase, I do only transmit, but in the second I will have to do packet receive. My idea was to make header easy to add/check/remove.
Altera provides Video-Over-IP reference design, which is exactly what I need, however I did not manage to make it running on Q10.1sp1, so I am doing my own.
