15 years agoData send thru ethernet
Hello, I am trying to do a simple task: I will form an UDP packet in hardware, then I want to move it to Nios, add IP header and send to ethernet. I will split my problem into two parts: ...
15 years agoHm, I am not sure, but I suppose IP header is a bit harder to add in hardware, because of header checksum. Maybe there are full (IP(UDP(RTP))) implementations in hardware?
I am checking UDP offload example now, too bad I am bad at verilog :)
