11 years agoData compatibility between simulink and altera blocks
Hi, first le me ask you, if it is possible to mix the simulink and altera blocks in one design? So can the dsp builder translate the standard simulink blocks into a vhdl file or qurtus projec...
11 years agoThank you for your reply @kaz
You mentioned, that i use quartus, then define I/Os in Simulink and capture the data?
