11 years agoData compatibility between simulink and altera blocks
Hi, first le me ask you, if it is possible to mix the simulink and altera blocks in one design? So can the dsp builder translate the standard simulink blocks into a vhdl file or qurtus projec...
11 years agoThank you for your quick reply.
Unfortunately these are no good news. I looked forward to use simulink because of the good diagnostic functions and the plot function of matlab. So, in Quartus these possibilities are very limited. As mentioned in an other post (http://www.alteraforum.com/forum/showthread.php?t=3462), the altera I/Os were used to translate the simulink data format into alteras data format. So it might be possible, to define a altera data entrance into simulink, doing the total processing in simulink and get the data out via altera outputs? Or did i missunderstand this post? In my example design, i could get the data into simulink, but i cannot convert it, that the altera output pin accepts the data.
