11 years agoData compatibility between simulink and altera blocks
Hi, first le me ask you, if it is possible to mix the simulink and altera blocks in one design? So can the dsp builder translate the standard simulink blocks into a vhdl file or qurtus projec...
11 years agoas far as I know, they are no directly compatable.
DSP Builder can only generate VHDL for dsp builder blocks. You need to use simulunk HDL coder (which is an extra licence from mathworks) to generate HDL from simulink blocks. Simulink blocks also require the fixed point toolbox (another licence extra).
