16 years agoDAM with frame buffer and Clocked video output
Hello In my design i am using Frame buffer that buffer video data in SDRAM and a Clocked video output IP in SOPC I need to integrate a DMA (direct memory access ) in my design between the fra...
15 years agoHello peet 2.
Now,I have a similar question.I use a buffer with RAM to buffer vidio data and I want to use DMA to transfer the data in the buffer to SDRAM. I know the avalon MM interface is needed, also I already know how to design the avalon MM interface. But, I don't know how to relate the DMA with the avalon MM interface. The question bother me so long ,can you help me,thanks very much!
