16 years agoDAM with frame buffer and Clocked video output
Hello In my design i am using Frame buffer that buffer video data in SDRAM and a Clocked video output IP in SOPC I need to integrate a DMA (direct memory access ) in my design between the fra...
16 years agoThe frame buffer use an external SDRAM to buffer video packets and then assign them to CVO as you said
My question is that i need to add a DMA (direct memory access) to that system to manage data . How could that be done ? Thank's for your help
