10 years agoCyclone V Transceiver Native PHY IP not available in Qsys
Hi, I'm trying to build a system based on the Native PHY IP core for the Cyclone V GX. This IP is available in Quartus, but it doesn't appear in the Qsys catalog... all the files are there, bu...
10 years agoTake a look at the Transceiver Toolkit documents at the top of this page:
https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html section 4 of this document ... https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_ttk_examples.pdf tells you how to turn on the "hidden" Qsys components ... As commented above, if you find bugs ... you won't get much help ... but at least you can try the components and decide for yourself. Cheers, Dave
