11 years agoCyclone V SDI ii IP CORE,how to use altera-modelsim to simulate?
Hi, Could you help me for three questions about Cyclone V SDI ii IP core? First question: I use two SDI ii cores, one for TX and one for RX, pattern gen ---- SDI ii TX ---- SD...
11 years agoIf you are using V-series devices, then I would suggest you to use SDI II IP core instead of SDI I.
For the SDI TX and SDI RX simulation, you should compile the sdi_ii_0001 in difference library folder. For evaluation purpose, you can just use duplex, I don't see there is a problem.
