11 years agoCyclone V SDI ii IP CORE,how to use altera-modelsim to simulate?
Hi, Could you help me for three questions about Cyclone V SDI ii IP core? First question: I use two SDI ii cores, one for TX and one for RX, pattern gen ---- SDI ii TX ---- SD...
11 years agoThanks for bfkstimchan and nic_@ replies.
Q1: The module name for both TX and RX instances are different, so I think this is a bug or I didn't use it correctly. My design only need RX,so I use TX to simulate it. Q2: I use TX SDI ii ip,it outputs tx is okay,but using sdi ip it outputs wrong. Q3: I know it's user created logic, I find the data register[31:0] phy address is 7'h3C. But I don't know every bit define for data register[31:0].
