11 years agoCyclone V native transceiver IP compile error , please help me,thanks!
when i use CycloneV native transceiver IP core, the function simulation is OK.But when i put the IP into my project and compiling the project,there will be some errors. The release of quartus is 13.1...
11 years agosorry,the problem has been solved that i forgot to instance the input port rx_serial_data.i am so remiss and embarrassed .
