9 years ago
Cyclone V GX PCIE Hard IP DMA problems
I used Cyclone V GX PCIE Hard IP with Avalon-ST interface, I don't use Qsys to generate the PCIE core, but use the IP catalog in the project.
Now I can receive the correct memory read data from PC, and send the correct data to PC by cpID TLP.
But the PC can not receive any data when I send by the DMA with either 3 header aligned TLP nor 4 header aligned TLP.
I have used the logic analyer to capture the DMA address which the PC send, and the address I send to PC in DMA is correct.
Does it need to enable some signal to open DMA function or need to adjust some signal before starting DMA?
Please send me a example of DMA tx of Cyclone V GX PCIE Hard IP with Avalon-ST interface but without Qsys.
Thanks very much!!!
