Cyclone V errata TLP Corruption in x2 Mode
- 2 years ago
Hi @NGord,
Yes, redesigning it to Gen 1x4 with only 2 lanes connected will provide the same throughput.
VenTing_Intel
Hi @NGord,
Thanks for reaching out to the Intel Community Forum.
After checking the records, the issue was discovered in hardware. It was found when corrupted TLP packets were sent by the PCIe HIP to the application logic when the link was in Recovery mode. The x2 mode has been removed from the IP Parameter Editor starting from Quartus Prime Standard Edition v23.1.
The options are to redesign the product to not use x2 mode; instead, use a Gen 2x4 with only two lanes connected, or a Gen 1x4 with all lanes connected. These two options provide the design with the same throughput.
VenTing_Intel
To clarify, if I am using Gen 1 2 lanes, I can simply change to Gen 1 4 lanes, 2 unused and I will get the same performance?
