10 years agoCyclone V - major transceiver misunderstanding
Hi all, I'm struggling with my understanding about Cyclone V transceivers in SX/GX devices. We have a custom board with 2 Cyclone V FPGAs. The one is an SX and the other one a GX device. ...
10 years agoHi Dave,
you are right.... maybe too much text. I attached the system I'm simulating on. You need to generate the qsys file into a subfolder called e_rtscpu_sx and then run "source run_simulation.tcl" in modelsim. It should start a 50us simulation, where the alignment is performed and after that "user data" is transferred. In the 16bit (FPGA to XCVR interface) version, everything works as expected. In the 32bit version, I get the above mentioned issue and alignment only works when I switch the received 16 LSB to MSB and vice versa. You are right, in practice, I may need additional encoding, but I first would like to get the bit slipping alignment to work and would like to test that also in HW. Just out of curiosity.... Regards, Maik
