10 years agoCyclone V - major transceiver misunderstanding
Hi all, I'm struggling with my understanding about Cyclone V transceivers in SX/GX devices. We have a custom board with 2 Cyclone V FPGAs. The one is an SX and the other one a GX device. ...
10 years agoHi Maik,
You need to learn to write more concise requests for help. No one will read a really long post. Rather than post a screen shot, post code, and a script that will run the code. I cannot tell from your description if you are using the 8/10B encoder. If you are not, then your data *MUST* have lots of toggles embedded in it to ensure the clock-and-data recovery (CDR) in the receiver stays locked to the data. Sending across a count would not meet this requirement ... it might work in simulation ... but not in the real-world. If you were using 8/10B encoding, then most of the synchronization should already be done for you ... or you should just use the SerialLiteII core until you have that working ... Cheers, Dave
