12 years agocyclone II ALTLVDS_RX ipcore issue?
i am using ALTLVDS_RX ipcore on cyclone II device, but meet a problem that rx parral datas are not correct. the following is the ipcore configration. any advice? ALTLVDS_RX_component.buffe...
12 years agoDo you receive the clock on a separate pin? You need to specify the timing relationship between clock and data. Are you using a pll?
